Warm Driver Side/Cold Passenger Side | Ford Explorer Forums
CoopakayakWI
Wisconsin
2006 Explorer Limited 4.6
Hello- I have a 2006 Ford Explorer with dual climate control. The passenger side blows cold and the drivers side is warm and never really cools off. It also sounds like a bird is squawking behind the dash every so often. I’m wondering if this a blend door motor or something in the back? Any help or recommendations on how to fix are appreciated.
Yes, it sounds like the driver side blend door is failing.
I know it's been a few years, but what did you do to fix it? I have a similar issue with my 07 Mercury Mountaineer (Electronic Climate Control, Dual Zones). Blows hot on the passenger side and cold on the drivers side. Good for me, bad for the wife, so it needs to be fixed. hahaha!
I had the same problem and it turned out to be an A/C compressor going bad. I haven't had the problem since it was replaced two years ago.
Thank you!
