Warrior schackle bolt hole size? | Ford Explorer Forums
toad
Blue Point, Ontario, CANADA
2007 Sport Trac
Warrior schackle bolt hole size? Help
I,m in the middle of building my shackles and have searched and found a bolt hole size of 5/8", for some reason this dosent sound right to me , can anyone confirm this please.
Thanks, Todd
This is from a thread I found-
I started drawing it in AutoCAD but got lazy...
here's the dimensions
Length: 10.25"
thickness: 7/16"
holes: 5/8"
end to center of hole: 1 7/8"
inside with of shackle: 3 1/8"
center cross brace: 3 7/16" from one end
(made out of 2" x 1 3/8" box steel)
The inside meas. dosent seem right either , if I measuere the stock ones its 2 7/8" inside.
Help
Bolt whole should be 9/16 I believe. Stock might be metric. The inside should be the same as stock I'd say.
Do you guys have any pics of these shackles?
The bolt size changed...
When they first came out I believe they were 1/2"
Later it was discovered that they should have been 14mm and the current ones are 14mm...
The factory bolts were an odd shape which caused the confusion.
~Mark
Thanks guys they are done and on the truck. I went with 9/16 hole and it fits great, I,ll try to get some pic.s
