warrior shackle demensions | Ford Explorer Forums
Clusterpup
Miami, FL
02 Sport Trac 4x4
Can anyone tell me the length of the warrior shackles from end to end and from hole to hole? I am going to make some shackles this weekend. I want to lift the rear end 2".
I am going to use 2"x1/2" mild steel. I shoudn't need to weld in a cross brace for this since I have seen some others without it and they used 3/8".
Bam!
http://www.explorerforum.com/forums//showpost.php?p=2198843&postcount=5
cant see anything there from that link
Sometimes I cant view some photos from work because of our firewall but I'm at home now and still can't. Anyhow I figured out how I'm going to make the shackles now I just have to figure out how to lift the truck high enough to install them, I just have a small jack and regular size jack stands.
Anybody know what the hole size is i just built mine and am not sure? Also wondering what bolts to use i know grade 8 for sure but do i need any specifc type to go with the leaf springs?
Stock uses 14mm bolts. Early War-153 shackles were built with 13mm bolts (1/2) and that was too small.
~Mark
Thanks for the help i guess its good and bad news, good that i know the bolt size and bad because that sounds hard to find! :D
Thanks thats great i think i will go there this weekend and get what i need!!!:D
subscribing...i wanna make some shackles sooner or later, and do a tt
