I've had both rust that ate through the fenderwell area (especially the seams), and having just the slightest leak in the side rear window, which turned out to allow more water in than the hole in the fenderwell. Age causes the window leak, the butyl ribbon just doesn't seal the same after awhile. Luckily that makes it easier to push the window out after unbolting to replace the seal.
