Water in cab | Ford Explorer Forums
Water in cab
Toady
Seattle, WA
2002 Ranger
Hi all, Newbie here, I have a water leak on the passenger side of my 2002 Ranger. It is not coolant, pulled the seat out could not see any obvious problem. Any ideas?
Windshield? Door seal? :dunno:
If...you have a sunroof, and the drain ports are plugged that leads away from the roof gallery, then the water will drain down the trim, along the windows and end up on the floor. You could also have a loose fitting window, that might lead to a similar condition. Additionally, if the rubber tube used to direct the water from the sunroof is broken half way down, it will also leave things damp.
It could also be leakage around the roof rack.
JP
Welcome! Did you check the glove box? You might have water coming in from the window/grille plate area.
check the vents below the windshield wipers if the truck has been stored or parked under trees excessive leaves, pine needles etc could have collected clogging the drains
Thanks for the replies. We dried it out throughly and ran water around the seals, windshield etc. no visible leaks. I guess we will just keep an eye on it for now. Thanks
