JAWIT
- February 13, 2019
- Richmond
- 2008 Mountaineer V6, 4.0L
Having an odd problem with the 2008 4.0L Mountaineer that has been going on for a few months now. Vehicle has the Auto Temp control (EATC).
Situation is that even when the EATC is set in the 80-90 range, the heat coming out of any selected mode (Auto, floor, defrost, vents) is barely warm. Ive tried enabling/disabling the dual button but that has no effect. Even when letting the vehicle warm up for 15 minutes and taking it for a spin around the block for an extra 10 minutes, and really getting on the gas, the air is still barely warm.
The upper radiator hose is hot like it should be, but the lower hose is only slightly warm after a spirited drive. The same goes for the heater hoses through the firewall to the heater core....the one closest to the passenger side is hot while the one immediately to its right is pretty cold. I believe the heater hose that is noticeably colder routes to the water pump. The heater control valve was replaced with a new Motorcraft part 2 years ago and that seem to be working correctly as the hoses on each side are hot to the touch. Only the lower radiator hose and the heater hose coming from the water pump are cold.
The radiator fluid has been replaced twice with G05 fluid in the last 4 years and there are no leaks in the system. I also replaced the thermostat housing with a metal one about 3 years ago or so, as well as a new Motorcraft thermostat at that time. Would the no/weak heat situation be caused by a failing water pump? I've never had an overheat situation and the temp needle on the dash has always been right in the middle. The radiator fluid level is always full when i remove the radiator cap and there is fluid in the overflow reservoir.
Any help would be appreciated!
JAWIT
JAWIT
