ramm
- December 3, 2009
- Dallas, Tx
- 2005 Ford Explorer
Hi all,
I am the FNG here, but have been browsing the forums for a while trying to find an answer to my problem.
05 Explorer -
Last week was driving into the office, and the lights started going dim(both internal and external) eventually the lights went out, I then drove the car for a mile. It started sputtering, so I pulled over when I started breaking it died. Had someone jump it off, as soon as the cables were hooked up all lights came on as bright as could be. Was able to drive it to Oreilly's had them test the alternator pushing out 14.33v. Went ahead and replaced the battery as it's about 6 years old now, also the positive terminal was very corroded when I removed the cover, so we brushed it off. Drove fine for a couple days then same thing started happening again.
Got it home, took the alternator off and had it tested off the car, all stages passed.
Hooked up the new battery to the charger and got it back to full. Drove it all day yesterday(for errands), about 4 hours of drive time; had all the lights, heater, radio going all is good. Then was pulling out of a parking spot, when turning the steering wheel the "check charging system" light began flashing and the ding sound. Made a couple turns like this and same thing. I reached down turned off the heater, and made a few turns no problem. Pulled it up in the garage, turned the wheel with heater on again and problem was re-created.
Hooked the charger back up to the battery, and only showed to be 65%.
So now I am at a loss at what it can be, multiple tests on the alternator show it as good. I don't want to run out and buy a new one and that not be the problem.
Any suggestions or if you have experienced this and found the correct diagnosis please help!!!
05 Explorer -
