Weird Fob Programming Issue: | Ford Explorer Forums
Oldbutslow
Allen
'02 Explorer Sport Trac
Programming a new fob successfully, I tried to use one of my old fobs. Not working, I replaced the battery and successfully programmed it. Did the exact same to my other old fob and it programmed. Grabbed the two that previously programmed and nothing… Programmed another successfully, and the other two failed. To sum up, only the most recently programmed fob will work. Any thoughts?
You may have to program them all in at the same time. Entering programming mode wipes out any previously stored fobs.
When you press a button on one to program it in, next press a button on the next fob and so on, do not turn ignition off yet or wait more than (20?) seconds to do the next fob.
Thank You! My two remotes are back in action.
