Weird problem with Stock radio | Ford Explorer Forums
rafairchild2
Western, New York
1996 E.B.
I have a 96 E.B. with a stock AM-FM-Cassette- 6 CD changer.
The AM works great
Cassette works great
CD Works fantastic
FM will scan and seems to stop at stations but I have no volume. If I crank it up I can barely hear anything.
Any suggestions?
Rick
It sounds like a bad headunit if the other am/cd/tape all work ok.
if you need a replacement let me know I have one in great shape that I know works.
Here is the front of my radio
FYI this is what I am looking for.
Distributed Radio Architecture
The radio pictured from your '96 EB is a Ford/JBL radio that features the "Distributed Architecture" of JBL systems used in Explorers and Lincolns from 1995 through 1997. The replacement head unit MUST have an -18C852- base part number (like the one pictured) in order to work. Other models of Ford radios, such as the midline cassette radio (base part # -19B132-), Premium Cassette radio (base part # -19B165-), or single CD radio (base part # -18C815-) will NOT work as a direct replacement.
You also need one with a "B" suffix in order to run your changer. The models with an "A" suffix are NOT CD Changer compatible.
regards,
Jeff
hmmm well mine is the part 19B165.
On second thought I believe the JBL system has a RCU rear control unit that does all the processing. That could be your problem.
Tuner is in the RCU
RiverRat is right, if there IS a problem with the FM tuner section of the radio, the FM tuner in the Distributed Architecture JBL system is in the RCU (base part # 18C851-) which is located behind the RR Qtr trim, attached the front of the Subwoofer enclosure.
I would suspect an antenna problem, and would be checking all of the antenna cable connections to be sure they are secure. The antenna cable runs from the RF fender back to the RCU in the RR Qtr.
regards,
Jeff
