welded rear end? | Ford Explorer Forums
welded rear end?
taiedman45
98 xl
i was watching trucks today on spike and i saw that they put a 8.8 ford rear end in a jeep. what they did is wielded the gear hosing to the axles. has anyone done this to there explorer? if so, did it help with off roading?
Welding the rear accomplishes the same thing as a spool without the cost (or a locker without being able to unlock). Both wheels will always be spinning together. That's great for rock crawling/mud, but not so good in a lot of other (higher traction) situations since the back of the truck always wants to keep going straight even when the front end is turning.
This is not something you'd want to do if you need to use the truck on the street much and can't spend a ton of money on replacing worn out rear tires. If your truck is only used for off roading and you're on a budget, go for it. For a multi-purpose truck however, you generally want a selectable locker or limited slip so the truck still works normally on the street, but has better traction off road.
Wait a minute...are you saying they welded the spider gears? Or are you telling us they welded the tubes to the housing? That is a more likely scenario to me and a practice that's been done for many many years.
They welded the tubes to the center section.
Ive done this on a few drag cars. It helps keep the center section from spinning on the tubes.
i heard of them welding the spider gears but i would not do it to my daily driver, around here we like to call that a lincoln locker
I've seen that episode and yes, I had the tubes of my rear axle welded to the housing. I've seen a picture of an Explorer (I think it was Rick's Pumpkin) with the pinion turned way up because the center sections spun on the tubes.
