welder amps? | Ford Explorer Forums
welder amps?
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
Do pretty much all welders require 220 volt outlets?
I'm not talking some huge industrial welder but something a person might have in their shop, etc.
Some run on 110/120.. Like the Lincoln Electric Weld Pak 100HD..
Our miller 135 is a 110V wirefeed welder.
~Mark
Yeah if you're going to just do body work (as this thread is under "Body Work & Detailing"), then a 110 v is perfect. I advise you go with a MIG and not a flux core because a flux core will burn through easier (runs hotter due to polarity -- electrode negative).
Thanks for the advice fellas. Makes me feel better that I don't *need* 220 in my garage. My friend's welder requires 220! But I'm thinking about getting a welder of my own
I will probably get a MIG welder. I just need to find a good one, I know nothing about them...yet.
It would be nice to have a welder than ran on even 220. Mine runs off 3 phase 230/480 and now I have no where to use it. :(
x2 -- a flux-core 110v is a very versatile and probably perfect unit for the home garage because its lightweight and the lack of a gas bottle means you can carry and squeeze it into pretty much anywhere you want as long as you've got a good 110v extension cord.
Earlier you recommended not to get flux-core ??
I was thinking of MIG...since I understand it leaves a cleaner weld and also is ideal for thin body panels, etc. Isn't this correct thinking?
Yes go with a MIG -- but for most off-roaders with a small budget who doesnt really deal with much body panels, a flux-core machine is the number 1 choice.
But in your case, a MIG is the only way to go -- it is very satisfying to be able to hold a bead on sheet metal accompanied by that distinct eggs-frying sound :), instead of burning through with a flux-core setup.
