I know this is an old thread but I got a question about one of the threads;
I used to have an 88 mustang 5.0 w/o the MAF.
When I was set to do some mods, and researched it I found that the next model year, they had the MAF,
but I didn`t.
I had a mustang magazine that highlighted mods, and they said if you didn`t have one then get one.
The explanation was that the MAF tells your engine how much air is coming in, so any mods which affected the amount of intake air would be better handled by the car`s computer. It also said you could go to a 70mm TB, and didn`t mention a new, tuned MAF
My engine was set to run at a certain value for incoming air, along with some other stuff like o2 sensors, etc.
What I`m getting at is if my X has the MAF, and I want a larger throttle body,what is all this talk about getting a MAF that is "tuned" for it. Isn`t it just an instrument for calculating incoming air? Why can we put cone filters on without a problem?
-Or can the MAF only calculate a certain variance in flow, which a throttle body would exceed, thereby sending faulty info to the comp?
Interested to hear more on this cuz I`m confused!
Oh yeah about the gears, if your shifter knob says 1-2-3-4-od then you have 5 gears, not counting reverse which is normally not counted anyway, because it is a ******* gear that gets no respect.
I`m kidding, look on your door sticker for the code, (bottom, towards right) then look in your owners manual for the translation (or put the code here, and I`ll tell ya)
