What do sizes do you suggest? | Ford Explorer Forums
jawilson60
Cartersville, Georgia
95 XLT
OK here we go. I have researched the sight and I think I have decided on something I just need some more suggestions. I have a 95 2wd XLT with 235/75/R15's. I have decided on a 3 inch body lift. I want BFG AT KO's. What size on the tires do you suggest? I am getting a PA body lift, does that include everything that I need including the mounting brackets for the bumpers. I dont really think that I can do this myself how much could a shop do it for? And what size tire shoud I get? Those are my two questions. Have fun. Please dont tell me to search because all that will do is confuse me.
Welcome to the site!! You'll find just about anything you want to know about your truck right here. Welcome aboard!
Good job on the search. It's the best way to start before you ask a question. You sound like you know what you want to do, so this should be easy. First there is no 3" body lift made specifically for the 95+ Explorer. Check out this thread, second post, a ways down regarding body lifts. Everything you need to know is there. Look for the heading "Making a Body Lift Work on a New Model."
Dead Link Removed
The body lift will include the bumper brackets to raise the bumpers, but they will need to be modified. The kit is not specifically made for the Explorer, and a little bit of custom work will need to be done. For these reasons (and maybe just because of the fact it's an Explorer (= rollover to some people)), a shop might refuse to install the lift. But if they agreed to install it, it would likely be expensive. You might want to talk around to a couple of 4x4 shops just to check it out, but don't be surprised if they refuse or give you a high $$$ estimate. Anyway, lots of guys around here have done their own body lifts and there are instructions available, if you wanted to get a couple of friends over for the weekend to tackle it.
With the 3" body lift, you should be able to clear 32" tires. But your limiting factor on tire size probably will not be clearance, but your gears. Check to see what gear ratio you have. You might not want to swing 32" tires with a 3.27 gear ratio. If you did, your acceleration would be poor and your gas mileage would decrease. So check your gears before you buy tires.
I hope this helps some. There's plenty of information already here on the boards. I know searching can be tedious, but the info is out there if you sift through it. Good luck!
