What jack capacity should i buy? | Ford Explorer Forums
PLRBEAR
Calgary,AB,Canada
95 EB 4x4
I'm looking at getting a jack and jackstands to work on my explorer. What should i get? 2.5ton jack or 3 ton? 4ton jackstands or 6? Thanks guys.
Get the strongest you think you will ever need. True, six ton stands are over kill for an X, but is that the only vehicle you will ever use them under? Same goes for the jack. Another benifit of using the srtonger equiptment is you never have to worry about it not being strong enough.
Thanks for the advice. I think i'll go with the 3ton jack and 6ton stands. That way, i can work under the vehicle with a piece of mind! :)
One other thing to look at is how high it is. I have a 3 ton jack and 3 ton jack stands.. They were great when the explorer was stock.. but now that we have a 3"ish suspension lift.. with 32" tires.. My jack is maxed out when it just hits the frame. My jack stands aren't tall enough to support the truck by the frame with the tires on.. (unless I dig holes in the ground.. which I've had to do before.. not fun)..
~Mark
Couple of weeks back I bought a new 3-ton jack to replace the 2-ton I already had. The new one has a wider wheelbase and is much more stable. I still have the 2-ton jack stands but will replace these real soon with heavier ones.
Chris
