Hey, there is one fairly inexpensive way to get 4" out of the deal, $100 for a bodylift, i like trailmaster but whatever., and i have seen 2" taller coils that didn't require new bracketry, just new alignment bushings, then the rear could be leveled out with longer shackles or an add a leaf. Hell my custom wound 6.5" coils were only $235 and that was at the big National boys, alcan springs or another of the smaller coil winders could make 'em cheaper, then again with $700 you could get the JD 2.5 lift and the body lift, i just don't want to see you spend money for stuff you're gonna wanna sell to go bigger in a year or two, i know i thought about the 4" superlift then the 3" body lift then i decided to go nuts cause i knew with a year or two of running i would want a bigger set so i decided 7.5" was the way to start. made my own 1" body lift, easy to do. i guess the more you are willing to do yourself and fab youself the less it will cost, my radiius arm crossmember and radius arm extensions i am doing my self. anyway before you decide really think about whether you are gonna wanna go bigger, the cost difference doesn't out weigh the cost on: ... buying a whole new kit selling the old and then because you went bigger so soon you have decent tires that look sill with too much lift. this probably doesn't help much but you can get a decent sized suspension lift for $700-$800. anyway have fun.
