steveissteven
- December 31, 2000
- LAS VEGAS, NEVADA
- '93 SPORT
What could cause the following symptom?
I have a 1993 Ford X-Plorer Sport....
When the fuel gauge reads 1/4 tank or less / vehicle runs great. (Full Power and very fluid... almost new)
When the fuel gauge reads more than a 1/4 tank, however, vehicle loses power, idles kinda funny (sounds like it has a slight sputter at the tail pipe), and just laks overall performance.
I agree, pretty strange. Any ideas???
The following have been replaced and or repaired!
1. New VSS (vehicle speed sensor)
2. New tranny
3. New intake manifold gasket replace
4. New radiator / hoses / water pump / thermostat
5. New injectors (about a year ago)
6. New MAF
7. New brakes
8. New Electronic ignition system
9. New FPR (Fuel Pressure Regulator)
10. New fuel pump
11. New O2's
12. New Catalytic Converter
13. New battery
14. New battery cables
15. New plugs and wires
16. New TPS (throttle Position Sensor)
17. New ECT (Engine Coolant Temp Sensor)
18. New Idle Control Valve
19. New Fuel Filter
20. New Air Temp Sensor
Your thoughts and ideas will be much appreciated.
Thanks....
2. New tranny
6. New MAF
7. New brakes
10. New fuel pump
11. New O2's
13. New battery
19. New Fuel Filter
Thanks....
