What will fit? | Ford Explorer Forums
What will fit?
slickemhoundd
Glassboro, southern jersey
1996 Limited 5.0
Just curious.... what other vehicles wheels will bolt up to my 2000 x? Im just in a search for 15s and im thinkin of pickin up stockies. And will any of the F-150 wheels bolt up?
Ahh Jeep 5 on 4.5" will fit.. Nothing F-150 wise will bolt up. Common wheel patterns are shared between Rangers, Cherokee, grand cherokee, wranglers.. Basically 5 on 4.5" bolt pattern is what you need.. Don't forget about backspacing. Stock is about 4", so anything from 3.75 to 4" will work.
I was curious about the f-150 because i thought it was the same bolt pattern but diff hub size (bigger) so i figured it would be managable. And are the jeeps the same offset?
Nope F-150s atleast the 90s ones were 5 on 135mm.. Explorers were 5 on 113.5mm? I believe.. Definately not the same pattern.
