RAST
- March 24, 2012
- MASCOTTE, FL.
- 2003 EXPLORER, 2001 RANGE
I have a 2001 4wd ranger. 4.0 SOHC. Motor needs some work and I am thinking about just swapping out the motor with another one. I think the counter balance shaft would be a non issue if the replacement was a 2wd motor. I keep reading that anything newer than 01 will not fit/work. Is this due to intake or other exterior bolt on parts that I can swap out? Newer Explorer motors are a lot more plentiful than older Rangers. I am considered a fairly competent mechanic, I just don't want to buy a motor that I can't use. Any input is appreciated.
Rick
Rick
