  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
What's this sound?
RickM
'02 Explorer 4.6 XLT 4x4
Hi all,
I asked this question before and in an attempt to address and was told the sound was a noisy torque converter. However, a few people told me it wasn't so.
So..... I've recorded the sound and uploaded to FileDen. This noise started with my '02 not long after new...maybe a year or so.....it would come in and out....now it's pretty constant. It comes from where I think the Flywheel is located and kind of sounds like a pulsing / rushing (water) sound. It comes in and out. I placed my laptop under the Exp but it may be too close to get the distinctive sound. It's a bit loud and sounds more like a raspy rattle.
If anyone can take a listen and give feedback I'd appreciate. I may try again from a bit further...it may be clearer.
http://www.fileden.com/files/2012/8/13/3336574/exp sound.wma
94Eddie
2010 Mountaineer Premier
It is hard for me to tell from that clip. If the noise disappears when the transmission shifts into overdrive then it is probably the torque convertor.
RickM
Eddie, Thanks for the reply. I'll try to get a better sample and check if it happens when going into over drive.
Is there any other way to test the torque converter?
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Hi all,
I listened to your audio and could hear it well(new PC), but it doesn't sound anything like the bad torque converter my EX had right after I bought it last year, Jan 2001. It was a cold winter here then and on a cold start up, the torque converter whined loudly. It sounded like a whiney power steering noise you could hear right thru the floor boards by the tranny/engine connection. Your sound seems more like something rattling around to me, totally different than what mine sounded like. BTW, the flywheel and torque converter are located underneath the Bell Housing of the tranny, where it bolts up to the engine. On older vehicles, they had a removable cover plate on the bottom of the bell hosuing so you could visually inspect the flywheel and torque converter area, but not anymore. Good luck with the diagnosis.
RickM
I will take a pic of where the sound is loudest. I sounds like something making contact with the flywheel in an on and off, almost pulsing, manner.
As mentioned, I will rerecord from a bit further away so the sound is more distinct.
Thanks
HCCA 250
IL
2002 Eddie Bauer
Isolate converter noise The 5R55N/W/S units have a TCC piston that floats
through the cover. In Figure 10 you can see the load springs
and the mating tooth patterns. Frequently and even with new
converters, excess interference and lack of spring load results
in a rattle, prevalent in neutral. This rattle is very difficult to
isolate and can be related to the flex plate, the inspection
cover, the camshaft sensor, the line control valve (review
above) or the converter piston.
These units require a flex plate alignment tool and during that
process the OEM paint/balance marks should be positioned
next to each other. Most converter rebuilders can supply the
tool and rebuild your converter with an updated piston
(Sonnax p/n FD-DA-17PB), to eliminate a TCC rattle.
To isolate the noise prior to removal, use the line control
valve test and alternate that test with a TCC command test.
This TCC command can be performed with a shift box or by
grounding the TCC solenoid pin 14. Verify you’re on the
correct wire or you have just added time to your repairs!
C Crazy loud screeching sound (+ loud fan) Stock 2002 - 2005 Explorers 11
T 2002 4.0 SOHC Intake Manifold Sound Deadening Insert Stock 2002 - 2005 Explorers 1
S Hi im shawn trying to figure out the rumbling sound from breather box 2003 ford explorer xlt Stock 2002 - 2005 Explorers 2
J 4.6L AWD strange rubbing/growling sound turning Stock 2002 - 2005 Explorers 13
T Strange Grinding Sound at Slow Speed Stock 2002 - 2005 Explorers 4
S 2004 4.0 2WD Intermittent/Irregular Ticking Sound at Idle Stock 2002 - 2005 Explorers 1
A Rocking Sound Coming From Behind Passenger Side Dashboard Stock 2002 - 2005 Explorers 9
C Amazingly Bad Sound - Wheel Bearings? Stock 2002 - 2005 Explorers 6
B Clanking type sound Stock 2002 - 2005 Explorers 18
X Clanking sound Stock 2002 - 2005 Explorers 2
8 sound like driving over rumble strips Stock 2002 - 2005 Explorers 16
L grinding sound from left rear wheel Stock 2002 - 2005 Explorers 24
D Bumping sound when taking my foot off the accelerator Stock 2002 - 2005 Explorers 1
0 Clicking Sound When Using the Heat. Stock 2002 - 2005 Explorers 1
B Rapping Sound From Passenger Valve Cover - 4.6 Stock 2002 - 2005 Explorers 4
R What is that quiet sound from my Explorer Stock 2002 - 2005 Explorers 5
S FM Radio no sound Stock 2002 - 2005 Explorers 6
S Is tapping sound likely a broken valve spring? Stock 2002 - 2005 Explorers 9
J Lug stud popped off/Fixed but now a new knocking sound (like cv joint) Stock 2002 - 2005 Explorers 2
D No power when cold Loud sucking sound Stock 2002 - 2005 Explorers 3
M Front end making awful sound Stock 2002 - 2005 Explorers 13
4 Strange Gurgling Sound Stock 2002 - 2005 Explorers 1
J squishy sound when pressing brakes Stock 2002 - 2005 Explorers 2
J High speed and loud clicking sound Stock 2002 - 2005 Explorers 33
A Ticking Sound when engine is cold 4.0 sohc Stock 2002 - 2005 Explorers 14
M Help with whining sound from transmission/transfercase Stock 2002 - 2005 Explorers 1
J clicking sound Stock 2002 - 2005 Explorers 0
D "SPROING" Sound At Left Firewall '05 4.6L Stock 2002 - 2005 Explorers 7
3 Diesel sound from 4.6L V-8 2005 Stock 2002 - 2005 Explorers 11
D OEM Stereo No Sound Stock 2002 - 2005 Explorers 2
S V6 explorer - mysterious droning sound at startup ? - video Stock 2002 - 2005 Explorers 3
O WHOOPing sound...rear left corner. Stock 2002 - 2005 Explorers 7
C Whoop Whoop Whoop sound from front wheel... Stock 2002 - 2005 Explorers 2
P short siss sound from back of passenger side Stock 2002 - 2005 Explorers 0
S Whining sound coming from engine compartment Stock 2002 - 2005 Explorers 3
D explorer 2003 guuruu sound from the front bottom Stock 2002 - 2005 Explorers 9
N rrrrrrrrrrrr sound.... bearing? Stock 2002 - 2005 Explorers 1
C Weird Turkey Sound from foot Vents? Stock 2002 - 2005 Explorers 2
1 Engine died but restarted with an odd sound Stock 2002 - 2005 Explorers 1
T Can a bad transfer case make a loud clicking sound? Stock 2002 - 2005 Explorers 0
T Loud "clank" sound while making sharp turns. Please help! Stock 2002 - 2005 Explorers 9
E Water sound in the golve box Stock 2002 - 2005 Explorers 4
F 'Knocking' sound in front end when turning Stock 2002 - 2005 Explorers 4
M Whooshing sound from intake mani+starting issues Stock 2002 - 2005 Explorers 0
J LOUD knocking sound coming from rear wheel area Stock 2002 - 2005 Explorers 2
H clicking sound as tire rotates Stock 2002 - 2005 Explorers 11
E Grinding sound at higher rpms???? Stock 2002 - 2005 Explorers 4
C Whining sound from alternator area... Stock 2002 - 2005 Explorers 7
E Weird Engine Sound I could use a hand in identifying Stock 2002 - 2005 Explorers 7
N New(ish) transmission "rattle" (recorded sound) Stock 2002 - 2005 Explorers 1
Similar threads
