mrsteve
- February 4, 2000
- Silver Spring, Maryland
- '98 XLT
Okay I bought some subs and an amp from a friend about a month ago. After I installed them I noticed that my right channel sub was making a buzzing sound every-now-and-then. Well today I was putting my subs back in cause I had taken them out to haul a new TV home. Anyways I decided to play around a bit and was going to run one sub of both channels or in "mono." Well I used the left sub cause I thought the right sub was screwed up. Well then the left sub was making the noise. So I hooked up the left channel of the amp to the right sub and it sounded fine. And then the left sub sounded like crap when hooked to the right channel. So I guess it's my right channel that is screwy. Now the buzzing sound is basicly constant but you can't hear it when both subs are hooked up cause the left sub sounds much louder. I was wondering if this has happened to someone else? Could it be something I did while hooking it up or is 1 channel on the amp just bad? Thanks. (Sorry that was kinda long)
