07EddyB
- November 18, 2011
- Bowling Green, KY
- 2007 Ford Explorer 4.6 V8
I'm getting a roar and vibration starting about 60 and trailing off around 75. Seems to be coming from the front. I can definitely feel it in the steering wheel and the drivers floor board. As it has gotten worse over the last month it seems to be louder in a left turn. The vehicle has 95K on it now. So - passenger front bearing - right?
Well - that bearing was replaced with a Timken in Nov 15 - about 10K ago. At that point, I was getting a vibration and went with replacing the OEM bearing with 80K+. I seem to recall that it helped but didn't go away completely. The driver front was replaced around 30K - the rears are OEM. I'm hoping against a rear - I don't have a press or an extra vehicle for extended down time.
That's the story - what direction are you leaning toward?
Edit - this is the bearing on the front right -
Timken HA590156 Front Wheel Bearing and Hub Assembly
