Wheel bearing/hub assembly | Ford Explorer Forums
brev1
Des Moines, IA
1999 XLT
Hi. 1999 4WD explorer. Left rear wheel bearing is going. I've been reading the posts on changing it and may give it a shot. However, since I've got the hub off already, I thought I'd just replace the whole thing. I've called a couple of auto parts stores and all they come up with when they check their inventories is the bearing. Can't a person buy the whole assembly? I'd like to work on it this weekend, with the holiday and all.
Any help is appreciated.
You don't have a hub on the rear axle. Bearing & seal only. The hub beraings started in 2002 on the 4 door Explorers & Mountainners.
To replace the bearing & seal you will need to remove the dif cover. Then the remove the carrier bolt & pin. Pull tyhe c-clips and slide the axle out. You will need a 5lb slide hammer to pull the bearing out if the axle tube and someting be it a piece of schedule 40 tube or bearing driver to put the bearing in.
And before you start all of this you have to make sure you can get the fill plug out first. If not you can not fill the diff back up.
...so i'm an idiot...
Thanks, Dan, for the response. I realized that when I called more places looking for something that doesn't exist. As a follow-up, is this something that a (relatively) average person can tackle? The way it's been explained doesn't seem to be overly difficult, but maybe that's me oversimplifying it???
It's not real hard. It just requires some tools that most people don't have. The 5lb slide hammer is a must. You can rent one. Getting the fill plug out can be impossible. Since you live in Des Moines it won't be easy as it will be a rusted in ****.
BTW my wife is form Des Moines. Her house was with in walking distance to George the Chilli King.
For a $5 part, it adds up in other things to do this.
You will need to purchase:
3 quarts of 90-140 fluids (synthetics are best IMHO)
1 new carrier pin bolt
1 tube of RTV sealant
1 set of axle seals
You should purchase & do this while your at it:
New brake pads
Turn the rotors or buy new
E-brake rebuild kit
Tips:
Do both sides.
Use thick paper to wrap the axle when sliding it back in so not to cut the new seal. Once in past the splines, remove the paper, then slide it in the rest of the way.
The diff only takes a tad bit over 2.5 quarts of fluids. Check the type of carrier for a possibility of needing LS additive.
A 3 jaw puller & a slide hammer can be rented for free at AutoZone or Oreilly's
Take time and care installing new seal. Use a dead blow hammer.
Never re-use a carrier pin bolt, they break from having spider cracks from vibration. Torque specs are around 12-14 lbs
Either use RTV alone or use a gasket & RTV for the dif covver. Make sure to go around each bolt hole with the RTV.
Warm up the fluids in hot water b4 adding. It thins it making it easier to squeeze out of the bottle. Let RTV set up for at least an hour before adding.
If the rear rotors are froze on the axle, use the 3 jaw puller to remove it after loosening the star wheel on the lower backside. This will release tension on the E-brake shoes.
Turn the axles so you can see the middle/tops of the C-clips for removal.
Put the lugs back on the loose axles to protect the threads on the studs.
Run a magnet in the collector depression inside the dif housing to remove any metals accumulated over the years.
Inspect the gears, LS clutches (if it is a LS), for any burning, or broken/chipped parts.
Does this sound like something you can handle? If so, I suggest doing it, as a shop most likely wont do much of the additional things. If they did, it would cost an arm & a leg. Better off doing it yourself to get it all done and save a ton of cash.
Good luck!
Huh...small world. I live across from Hoover High School (Just NE of Merle Hay Mall).
One more stupid question...
So i called the parts store and they asked me if my X has solid suspension or independent suspension. Does anyone know the answer?
nevermind...
Told you it was a stupid question
