IllmicIll
- September 13, 2008
- 2004 XLT
I was driving on the highway yesterday when the car just started swerving more and more gradually but quickly got worse. It got so bad that I couldnt control the car going 20mph. I had to have the car towed. I also smelled something burning. The car has had a humming noise under power for a long time now and I was not sure what the problem was but after doing some search it seems to be a wheel bearing. (or maybe even the diff?) I pulled the car in the garage this morning to work on it and the squeaking noise was really bad. Rear right wheel is definitely the problem.
Does it sound like a brake lock up or the wheel bearing? also, how do I slide the rear caliper out to check it is not a brake lock? I pulled out the two caliper bolts but the only other remaining bolt seems to be the one that holds the brake line to the caliper. I read that theres 3 bolts total to remove but it just seems to me like that bolt is a banjo bolt and I am not about to loosen that if it is.
Thanks in advance and ASAP would be great.
