Wheel Spacers | Ford Explorer Forums
Wheel Spacers
yourmoma717
Norfolk, Virginia
92 SPORT
Could I put wheel spacers on my wheels to be able to put bigger tires on my truck without rubbing when turning sharp?
no they would rub more
wheel spacers will make it worse
coil spacers will make it better
thanks
then why does back spacing help from rubbing
it depends where its rubbin
Not to mention that the front wheel bearings are unhappy at best when stock. wider wheels/spacers will amplify the problem. You want a Sawzall:p:
yes a nice millwalkee
a sawzall won't do any good if he is rubbing on the sway bar/radius arm. You arn't going to trim either of those.
What's a sway bar?:D
If you're rubbing on the radius arm, you've got deep backspaced wheels, and spacers will put you back to a 'normal' 3.5 to 4" bs, or the opposite, and your scrub radius is gigantic, or your tires are HUGE, or your steering stops need to be adjusted.
