where can I get a center axle disconnect motor? | Ford Explorer Forums
team
Like the title says, where can I get another CAD. Is the junkyard the only place?
discount ford dealers maybe?
It's not actually a motor. It's a vacuum actuated solenoid and they are rebuildable. You might be able to get the part from Fast Parts Network . Check with Torrie@fastpartsnetwork.com to see if he has what you need
maybe he is referring to the slide unit in the axle?
I kind of like that disconnect feature, because you have true 2wd and it saves wear and tear on the axle and xfer case.
yes, i am referring to the vacuum solenoid
