ARexplorer
- April 16, 2006
- Long Island, NY
- '96 XLT
i've been lookin for lifts, if i do find one, theyll be around 2000 bucks. is there any cheaper? thanks
explrths said:ANd the brackets. I had to make my rear brackets. Other then that, be prepared to swap your hub bearing assemblies and halh shafts. mine went after 6 months. As far as brake lines, you dont need anything. You will need to trim your lower trim pieces ( and possibly pound the metal back ) depending on the tire you run. All of mine have been "taken" off, including the front valance. ( thanks to a stepo grade i had to back down.) I did use longer grounding straps in a few places, but they needed to be done.
