Where do the hoses for the DPFE go? | Ford Explorer Forums
a94exp
Marion, WI
'94 XLT
I just purchased a 94 Explorer with a 4.0L. I noticed that it looks like what is left of some old broken off rubber hose is stuck to the two nipples on the DPFE switch. Where do they go? I see that there are two tubes sticking out of the large tube that runs between the exhaust manifold and the EGR valve is that where they go? Thanks!
That tube connected to the exhaust manny is your EGR tube...and yes those 2 smaller outlet tubes should connect to your DPFE via the small black hoses. BTW: make sure you get hose replacements specific for the EGR system, regular silicone hose is not heat rated for this application and will melt off!
