Devo55
- September 25, 2021
- Los Angeles, CA
- 1993 Explorer Sport
I have a 93 Explorer Sport 4.0 with a whopping 365,000 miles. Recently the it just stopped 1-2 shifting. I was driving along then I felt a whoosh, like a balloon releasing it's air. My truck went straight to first gear. Luckily, I was on a back street with no traffic because I could only do 20mph after that. Now when I drive I have to let the rpms go to 2000 then ease of the gas until it drops to 1500rpms and it will shift into second. I changed the modulator (with a Duralast MVP14 from Autozone) and it didn't fix the problem, infact, it got worse. It still wouldn't shift automatically, l had to let off the gas to get it to shift gears but now the tachometer had to climb to 3000rpms and only then it would sometimes shift into second gear. Sometimes it would jump back to first gear without warning. I suspect the modulator may have been bad in the box or just the wrong one. I pulled the Duralast out and put the old one back in, because no nearby auto parts had one in stock and need to drive to work. I ordered a new modulator online and should be here in a few days.
Side note: I tested my old modulator with a vacuum and it held 20 -17 inches of vacuum for almost 7 minutes. Pretty good! The hose did have a bit of ATF when I pulled it off the transmission though. The Duralast held 20 inches of vacuum for a few mins too but it's definitely not right for my truck.
So my question is, does anyone know where does the vacuum line from the modulator connect on the intake manifold? I want to make sure the line the vacuum line has no leaks, but I can't find where it connects exactly. I tried to follow it from underneath the truck but got lost in the maze of wiring. It's also very sketchy on diagrams. I need a picture. "This is the A4LD vacuum hose --- it connect here". Any Ford scholars there?
