Where is the cd load button???? | Ford Explorer Forums
vanessa2155
Nashville Tn
2010 Limited
My 2010 Limited had a 6 disk player but for the life of me I cannot figure out how to insert more than one disk at a time! I cannont find a load button or where to choose another disk slot to add another disk. Help??:scratch:
If yours is like mine, it's just to the right of the slot, with the eject button above it. Push it once, and it prompts to select a number for the disc position. Mine is an '06, so that may be different.
No, mine does not have that. I can't even find a picture of one like mine on the internet anywhere. I will take a pic of it tonight and post it. So weird.
On the left side is a button that has VOL and PUSH. The right side button has TUNE and RPT.
According to the owners manual for you Truck, The load button should be on the left side of the CD slot just under the eject button. I reccommend you look at page 50 of the 2010 Ford Explorer Owners manual 2nd printing!
Here is a link to the manual http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=2010&make=Ford&model=Explorer
This is what it says on how to load
LOAD:
To load a disc into the
system, press LOAD. Select a slot
number using memory presets 1–6.
When the display reads LOAD CD#,
load the desired disc, label side up.
If you do not choose a slot within five seconds, the system will choose
for you. Once loaded, the first track will begin to play.
To auto load up to 6 discs,
press and hold LOAD until the display
reads AUTOLOAD#. Load the desired disc, label side up. The system will
prompt you to load discs for the remaining available slots. Insert the
discs, one at a time, label side up, when prompted. Once loaded, the last
loaded disc will begin to play
Not this one?
