Where is the fuel pressure regulator? | Ford Explorer Forums
GenerationX
Clio, MI
'94 Limited
Can anyone help on where it is on a 94 that came without egr? I've looked on the fuel rail but where I can't see is underneath the plenum. thanks and have a good one!!
It should be on the passenger side on the fuel rail two connections vacume and the fuel line itself I think it is two 10 millimeter bolts hold it down.Hope this helps
hmmm... it must be under that DIS coil. I guess I just didn't see it with the bracket being in the way. thanks much, 88!
If you need more help just drop a line,I just changed mine out last summer real easy to do make sure you relieve the pressure first
did you just disconnect the fuel pump relay and crank the engine? which leads me to another question: where the fp relay is on that thing...:confused:
Is that the best way to relieve the pressure?
There is a few different ways to do it.In my opinion pulling the fuel pump relay and cranking enginge is the best way.I have seen it done without releiveing pressure and just putting a rag over it.I think you can use the scrader vavle too but I have never done it that way.Fuel pump relay should be on the passenger side right next to the air box.Little black plastic box
Or you could pull fuel pump relay while it is running.
ok...I think i'll pull the relay and crank it...doing it while it's running sounds scary...oh yea my dad has a schrader pressure guage with a relief valve, too. I could use that.
let me know how it goes.Good luck
