lifttruck2008
- May 24, 2008
- 2001 Sport Trac
So on a trip last weekend the rear window on my 2001 sport trac stopped working. I had a chance to look at it tonight. Before I did anything I ran the reinitialization procedure. I ran it a handful of times. Everytime I got to the full up part I would hear the motor click and then nothing.
So I pulled off the back cover and ran the electrical diagnosis posted here, that is from the fordtechservice website. Passed all the steps until the ground check. Far left pin was 4ohm(within spec) far right was 7ohm. Out of spec, but close.
Anyways I pulled out the motor and used a body tool to turn the window gear. Wow was it tight and hard to turn. I pulled out the drum with wire and pumped some red synthetic grease all over. Made a day and night difference in hand turning. I know ground spec was out, but with how hard the window was to move I have doubts on the motor.
Where do these ground wires run?
Where can I get the window motor? I looked online but never saw a rear window motor listed. Is this a dealer/junkyard part?
