Thallarsen
- February 21, 2000
- Potomac, Maryland
- '99 5.0 Limited AWD
I'm guessing that this is a common problem....my tranny isn't leaking, but I'm losing ATF at a pretty fast rate. I have the pinging that seems to be associated with ATF being sucked up into the intake thru vacuum line(s), and the oiliness around the intake 'tree' on the upper manifold.
Assuming that the ATF is going up through the intake, it seems like a common diagnosis is replacing the modulator valve. It also seems like this is not an easy task with too-often poor results.
Any other possible diagnoses, or opinions on modulator valve repair/replacement?
Thanks,
J.P.
'91 XLT
Running great @ 210k but with some pinging......
Thanks,
J.P.
'91 XLT
