Which Coolant to Buy? | Ford Explorer Forums
xwhaler
Dover, NH
2000 XLT
I apologize if this question is not worth asking but I always like to check around before I buy anything for my X.
Which Coolant are you guys using? I'd get it at either Wal-Mart or one of the local Parts stores around here. (AutoZone, PepBoys, NAPA)
thanks
I always use Prestone.
Whatever is on sale but no generic brands.
usually Durex
Originally posted by Ford_Racing_Guy
usually Durex
I sure hope you mean Zerex, because Durex makes something else...;)
Anyway, I use Prestone Extended Life 5/150.
(Had to add the smiley!)
lol
if your leaking coolant its ok to use some cheap coolant...otherwise i'd say buy a preimum brand
Question???
And now that you are talking about coolant and you said something about leaking how much is a leak? Because I add some water every month or so. Is this normal? or is it normal?
I usually buy the cheapest.. Then again, I always do a flush every year.. Also most people using regular tap water however distilled water is recommended. Also if you have a GM product like I do, and the Dexcool antifreeze that came with my truck has been shown to cause damage to the engine. I noticed it one time when I rubbed the inside of the radiator with my finger and noticed a black greasy substance inside the radiator. Needless to say after I found that out, I changed it out to regular ethylene glycol based antifreeze.
ok thanks all
my dad reccomends that I use De-Ionized water (Not Distilled)
Use what the manual recommends, a name brand with distilled/deionized water. Change every 18 months. I would not use the orange - too many stories about gunking up.
