KKM
- August 30, 2002
- Kansas City
- Ford Performance
I have tried telling my customers for quite some time that the noise has always been there, you just hear it more with an open element air filter.
I have traced the noise to two seperate sources; One being a hanging and dirty IAC valve, which you seem to have addressed. Two being harmonics in the crankcase vent line. Try restricting the vent line slightly, with a hose clamp or zip tie from it's current diameter and you should hear a change or elimination of the noise.
On other Ford models, the noise has been quite bad. They resorted to installing a large foam sleeve over the vent line as factory standard on the 95-97 2.3L Ranger because it was so bad.
