Sal
- October 19, 2003
- Long Island, NY
- '98 XLT
I have 98 Explorer XLT AWD 8cyl with 142K miles. I've been trying to track down a whoop-whoop sort of noise I get while rolling along. It isn't coming from the engine. I notice that when the car sits for a while (overnight) I won't hear the noise until I travel a short distance of say a mile or so.
If I apply the brakes a bit the noise is eliminated or at least quieted down to where I don't hear it.
I believe I hear the noise coming from the front of the vehicle.
I check the play in all the wheels by pushing and pulling from the top & bottom. There wasn't any noticeable play.
I also checked for bearing noise by turn the wheel left and then right while moving along at a fairly low speed. The noise was there only when I leaned towards the left (loading the right side). I swapped out the front right hub bearing with a new one but the noise is still there. I'm not too surprised because the wheel turned fine with the old hub and, sure enough, after I removed the old one it seemed to be in good shape.
I have about 1/8" play when I pull on the rear wheels (in and out). However, I read that is typical and something to do a C clip used to retain the axle.
I suppose it could be the rear hub. However, when I check it, all seems OK so I'm hesitant to replace the rear right hub.
Also, the front L/S half axle and the front axle were both recently rebuilt by a good rebuild shop and are in like new condition.
I'm going to try to get the truck up on a lift and put it in gear to see if I can pinpoint the source of the noise.
Brake pads, rotors and calibers all seem OK.
Any ideas of where this noise might be coming from?
