Wierd Power Window Behavior | Ford Explorer Forums
Awesome96XLT
96 xlt
Hey guys. I have come onto the forums before for other fixes like my fuel pump replacement, so I know you guys can help! This time, my drivers side power window is rolled down and will not roll up. When I click the switch to roll it up I do not think I hear any clicking. When I click the switch to roll it down, I sometimes hear a click inside the door while other times I hear a click in the dash. Furthermore, I hear a short, faint, wierd, screetching or grinding within the door that lasts for only half a second sometimes. Does anyone know what might be the problem? Is there any way to manually get the window up as a temporary fix (don't want to leave it out overnight like that). Anyways, as usual, thanks alot guys...:us:
Pull the inner door panel off and take a look inside, see what works when you try the switch. Try lubeing the window mechanism with WD40 or Liquid Wrench to get it moving if stuck. If nothing works, you can probably manually raise the window.
