The 265's are alot bigger . I have them on my ninety eight eddie baurer. They measure out to be 31.6x10.6 which if you went to get to get some thirty two eleven fifty's they would measure out to be the same. the answer to your question is not without rubbing . But you can go get your torsion bars turned and go to auto zone for 12 dollars and get some 8.5 inch shackles part# 81400 and I got about two to two and half inches of lift but it depends on the code torsion bars and inch shackles you have on it stock . The setup will probably cost you 50 dollars or so in the end . The two sixty fives look so much better though .
