will 32x11.5x15's work on a tt/shackle explorer | Ford Explorer Forums
pgh, pa
'99 limited
Hey all. I got a 1996 sport and i just did a tt with the factory bolt and a rear shackle lift. Will 32x11.5x15s work on it? how bout rubbing wise or watever? anyone ever try this setup? Thanks.
ive been thinking about putting the same size tires on my sport trac, and ive got a tt and 2in shackle lift. would spacers be required at all, as well?
where are you all getting your shackles i got a 01 2wd sport trac and I want to do the tt and the shackles. i just ordered 17x9 rims with a offset of -12 and the stock rims are +12 so it is going to bring the tires out almost 2" but i want to do that first to see what size tires i can run.
I run 32's with just TT/Shackle setup and it was fine, just minor trimming on the back of the front bumper, to clear the wheels turning. Wheel spacers are not necessary, more for looks if anything.
I'm running 32x11.5x15 on my 96 with a TT and 2" lift leaf springs and have never had a problem except for mino rubbing on the front sway bar when at full lock (but only when going in reverse :confused: ). I solved that by removing the front sway bar. Oh, I and don't have any wheel spacers.
does anyone have any pics of there explorer or sport trac with just the tt and the shackles setup with the 32s I would like to do the body lift and tt but dont want to lose anymore gas mileage but i still want to go have some fun at mud fest and bambo fest
and where can i find shackles for my truck or do i need to make them
http://www.warriorproducts.com/
Item # WAR153
Or you can make your own, and some people even run the AutoZone shackles. You can find pics of my truck with 32's in my vbGarage (click on my name <---)
