beleneagle
- October 3, 2010
- Belen, New Mexico
- 90 Bronco II , 96 Ranger
Another thing I just thought of. if it does fit, the distributor gear will need to be swapped with the cam sensor gear as the cam material is different between the two motors. The 2.9 uses a soft cast iron flat tappet cam and the 4.0 uses a steel roller tappet cam. The two gears are not compatible with the other cam.
David
David
