ssp.interceptor
- February 5, 2010
Tires are definately causing some of that for sure, gears are stock 3.73. I'm waiting till I'm sure that 31-10.50s are big enough. Don't want to regear again if I re-skin with 33's.
As far as the trans goes, I'm at 165K now so a rebuuild is at least minimum and I know I'll spend more in upgrades cause I can't leave well enough alone. By the time that is said and done I could have bought the 5 speed, flywheel and new clutch. Then I'll have full control and most importantly, be happy. Not to mention having a unique combination. I had a guy crawl under my truck to make sure the transfer case shift linkage was actually attached to something!
Thanks for the link on your heads rj, I'm going to check it out now. I still need to pick up a pair of buildable P heads. Only ones I've got are on the truck and I can't have that kind of down time. I've got a pair of E7's that need to go in with the next load of scrap. Actually, I may keep one of them in case I ever get a boat, if you get my drift.(pun intended)
"I just got a junkyard explorer motor with a STOCK cam. Wanna run um'? I just what to see how badly I get beat."
AAAAHHHHHH.... The Good Old Days....
Fixed that for ya...![]()
"I just got a junkyard explorer motor with a STOCK cam and it's SPEED DENSITY. Wanna run um'? I just want to see how badly I get beat."
Thanks for the experience all. I think I've been swayed to retain my stock cam and a couple hundred bucks. Let me pose this question, What effect will 1.7's have on the characteristics of that stock cam? I've heard they will actually shift the powerband up, and would be counterproductive for what I'm trying to do.
as you probably know, that will only give you more lift.
more lift with small stock heads will decrease torque, and the added lift will provide little if any added flow so don't expect much higher rpm gains.
once you lift a valve more than a certain distance (relative to the valve diameter) you gain nothing. so higher lift is only beneficial with large valve heads.
also keep in mind that higher ratio rockers increase stress on the cam and lifters. which is guess isn't a huge deal for a roller cam... it will also lower valve float rpm (although that may also be a non issue as it will still do 5500 or more)
as for the "letter cams".. personally i think they are great. but they don't produce much low rpm torque. they are a mid to high rpm cam. for good performance in a heavy vehicle, you'd need a matching torque converter (cam range for a b303 would be say 2700rpm and up, so you'd need about a 2500rpm stall)
