ssp.interceptor
- February 5, 2010
The main reason people choose 1.6s over 1.7s in our trucks is fitment. A valve cover high enough would require an intake spacer or header issues if you use the FMS headers. Not sure about Torque monsters.
Funny thing is I have had a set of 1.6 pedestal mount roller rockers for about 4 years, just waiting on cam swap to use them. I never felt like installing them on the stock cam since factory is 1.6 already.
How would the roller rockers affect header fitment?
I was actually talking about valve cover clearance. The drivers side fms header on my truck does not allow for much extra clearance over stock valve cover.
I also notice most people are running cams on basically stock gt40p motors have at least .500 lift.
Rear (and possibly Front) end gearing, transmission gearing, tire size, TC stall and vehicle weight (or intended towing max weight) all play a role also. Always keep that in mind.
Gotcha, that makes sense. Can't the oil baffle be removed on stock valve covers to clear rollers?
