Will it work? | Ford Explorer Forums
Will it work?
haywyred
Watervliet,Michigan
'96 XLT Sport
Hay All. Can anyone tell me if an Auto Trans from a 96 302 EX XLT bolt up to a Transfer case in a 96 EX Sport. Ive read so many post from seaching I can't see straight.:confused: Thank's for any help. :)
With an Advance Adapter's AOD to 1350 adapter it will.
How do you plan to bolt it to the motor?
You thinking of bolting up a 4R70W to a 5R55E?
A 4R70W to a BW4405. :)
How do you plan to bolt it to the motor? With really long bolts. :rolleyes: Sorry coun't help myself. I'm doing a V8 swap into my 96 EX Sport. I want to keep my TC if I can. Not sure on the kind of trans it is. There is a plate mounted on side but I don't know what all the numbers mean. My 96 EX has the 2D,4WD Auto,4WD Low Knob. If I get the adaptor from AA will I have to modify the cross member mount?
I had to modify mine because I am using the 9" adapter. But there is a 5" adapter which would have taken less modification. You can search for stadx2's write-up for all the info and parts you will need for the v6 tcase part of your swap.
