dssranger
- January 4, 2006
- Central Coast,California
- 1986 XL 4X4
I have the following problem with my 86 Ranger 4X4, It just happened one afternoon, I cannot engage the transmission when the engine is running. Turn off the engine and it engages any gear. I had to drive it when this happened. After starting out with the transmission engaged it does shift, but very hard.
I have 60K miles on a new clutch. I have the same on a rebuilt eng. So I need to repair it. I think it is the clutch master cylinder. But realized the transmission
must be removed for the hydraulic line is in the bell housing. I had an idea to go around this, Is it possible to cut the hydraulic line and replace the clutch master cylinder and then splice it back together with compression fittings?
