will the speedo be off..if at all? | Ford Explorer Forums
Ak LTD Xplorer
Anchorage Alaska
1996 LIMITED OFF ROAD 4X4
im goin to be putting 31x10.50 tires on soon and i want to know if i will need to reprogram my speedo? i have 28's on now and everyhting is right..but with 3inches more screw with the speedo?
thank's
you should probably go to a speedo gear 1 tooth smaller.
Yes it will. You'll have to save up and drop $11 on a new speedo gear! :p :D Or just deal with it. It will be about 3mph off at 60 I think.
so it will say 60 and i will be doing 57?..where do i get the gear? how do i replace it?
It will say 60 and you will be going 63.
where can i get the gear tho?.. thank's!
Your local Ford Dealer. It's a 5 minute deal to pull the gear out, see the color, then get the next step up or down. :cool:
where's it at?..i have no friggin clue so any help would be nice!!..thank's!
On your transfer case. It's a little sensor all by itself held in with a single bolt.
ohh easy..what color do i need?(perfect im going to the dealer after school)
Depends on what you have now. You have to either determine the color of the one you have.. or there is a chart somewhere that you use your gear ratio and stock tire size to determine what you have. Then just add or subtract teeth and it will be a different color.
Now when I went to the dealer, I HAD to know what color I needed.. Cause they couldnt tell me the teeth count or anything. So research the heck out of it here before you going telling them you need a 21T gear.
i will just pull it out before i go and bring it with me so i will need a size smaller(it's what alec said so it must be right?)
thank's section!
Look kid I have like 5 speedo gears sitting around let me know and I will hook you up with one for free. Heck I will also help you install it. Only takes a few minutes especially if you have your own garage.
