Will these fit (Just to be sure) | Ford Explorer Forums
sexyhex
Hickory, NC
2003 XLT
I browsed and searched around these forums and the internet, so I think I've pretty much found my answers, but I'm just clarifying to make sure I didn't get my information mixed.
Will my Toyo Proxes 275/30R24 fit my stock 2003 Explorer XLT without rubbing. Obviously, these aren't stock wheels. I don't want to get flamed for asking, I'm genuinely interested. I had a hard time understanding the sizes and fitments before I started reading here so all help is appreciated.
They should - they work out to be the same rolling diameter as 265/75/16s - ie around 32" tall.
Well, wheel and tire are both 10" so it should be okay and I halfway expected some rubbing on a full turn, but that's something I can learn the first few times about how far to not turn, you know?
Also, thanks for posting that thread, like I said, I read and browsed around a bit before I asked, I just wanted clarification! Thanks for the help!
Some things you may want to consider also is what the offset of the Rim is and also the tires are techincally a little more then 10.5 inches wide. so calculate that as well so you can be sure that they will not rub or you can trim where they do.
