Windows and door panel question... | Ford Explorer Forums
spotdog14
East Lansing, MI
'02 XLT
Hello, so my g/f has a 95 x limited.
So, for some reason the window now goes up crooked. THe front does not rase. So i figure that one of the tabs or somthing broke, so i tried to take off the door panel to check it out, and i couldnt get it off with out breaking it.
SO how do you take off the door panel? and also what would be wrong with the window??
Thanks!
To remove the door panel:
1: Remove the 2 screws located by the door handle and the one in the upper front part of panel.
2: Using a thin flat screwdriver gently pry out the door handle trim.
3: Starting at the bottom corner, use a panel removal tool or thin wide screwdriver and gently pull the panel away from the door to disengage the trim clips from the door. Once you get it started, you should be able to use your hands to pry the rest of the clips out.
4: Lift the panel straight up to disengage the hidden hooks from the door frame.
5: Depending on how much room you need, you can either disconnect all electrical and move the panel or leave it hooked up and rest it on a box/bucket.
Here's the locations of all the clips:
That helped ALOT thank you guys!!! It seems that the window somehow poped out of hte little bracket that holds it in the front, and i tried to pop it back in but i ended up poping it all the way back toward teh out side, it was on the inside...so now it just rides the regulatar bar up and down, i guess one of these days i am going to have to break out the socket set and take the regulater bar apart and glue it back into place...
But thank you guys very very much!!!
