Windshield washer problem | Ford Explorer Forums
bookit
Charlotte, NC
2001 Sport
Hi - New to the forum. Thanks in advance. 2001 Exp. Sport - front windshield washer not working (wipers working fine)- the back one works - both washer and wiper. Don't know where to start. Help !! Thanks again.
this really should have been put in the 2nd gen Sploder area...
but, it's probably the malfunc.... errrrr, multi-function switch.
the washer part of mine is finnicky... has to be pushed just right to get it to spray washer fluid.
Thanks
Thanks for the help.
Swap your front washer relay for the rear relay. They are in the junction box
in the engine compartment.
Steve
Steve -
Appreciate the info - will try that right away.
It may still be the switch, but on mine the relay was the problem. Its an easy check before you go buying a new switch.
Steve
