wiper washer fluid pump, | Ford Explorer Forums
katt68
halifax, nova scotia,canada
1992 xl
my 92 ex has a new wiper pump in it but the passenger side of the windshield is getting neglected. i get lots of spray on the drivers side but just a trickle on the passenger side. the hose to the passenger side is clear, i can blow through it. any ideas how to get more pressure/fluid on the passenger side of the window?
Its got to be clogged somewhere in that line:)
Make sure that you don't have any leaks in that part of the tubing, that would reduce the pressure at the nozzle.
The other possibility is that the nozzle is (partially) clogged.
if you have waxed it you might have gotten some wax in the holes in the nozzle
All excelent answers.
As a test , unplug the hose at the bottom of the squirter , pull the lever , see if it gushes out.
If it does , it is the squirter , if it doesn't check the hose or the Y.
