huskyfan23
Rah no Hans Bwix
- November 21, 2002
- WA
- 1994 XLT 4x4
Ok, I didn't have a good connection on a switch of mine. This switch was wired into the cigarette lighter wiring. I disconnected the power from the switch to get it a better connection, and it accidentally touched the ground wire. There was a spark, and then the switch didn't work anymore. I also noticed my radar detector wasn't working... My radar detector pulls ground from the cigarette lighter socket, and power is wired into the radio fuse. The radio fuse is fine, radio comes on, as well as my speedometer which is also wired into it, but not the radar detector. I tried regrounding to different ground wires and I still got nothing. The cigarette lighter fuse is one of those big silver "circuit breaker" fuses, right? My flash-to-pass still works, and I bought another of those just to see if there was a difference, cigarette lighter socket still doesn't work. I really don't see what could have happened. Everything is protected by fuses, so they'd blow if there was a problem. The radio fuse doesn't even give power until the key is in the ACC position, so I don't see how that could've done anything to the radar detector. I just thought of something, maybe try the radar detector in another vehicle (DUH)! Anyways, until then does anybody have any ideas? Could the ground touching the power have sent power through the ground wire to the radar detector? It's a Passport 8500 with one of those smart plugs, so maybe I just blew the smart plug? Thanks!
