douglaswmoyer
- April 21, 2006
- Sacramento, Ca
- '92 EB
thanks Glacier- New thread per your request:
My 92 exp. quit pulling about 4 blocks from hame and i barley made it back. i kept reving it 2 to 3 k rpm to geet 20 to 30 mph. oil level ok, pulled pan and found that filter was way dirty. I had been changing the oil every 10,000 miles through a drain plug not realizing that the crap was still being trapped in the filter. So, changed the filter and 3 qts. of oil and it would go ok (I had warmed it up to check level) next morning i found it will not shift ino 2nd gear for about 4 blocks the shifts ok the rest of the day. this morning it shifted ok for the first time. took to ford and they said internal seals/gaskets prob. the cause possible the govenor. Should bve overhauled with this many (165,000) miles on it. I'm only concerned about if I should keep driving this way and how to fix the problem.
